Have an old hydrospray system
Kyle1
Let’s back track how would I wire up this the circuit breaker to the transformer
The "hot" side of the transformer need to split off and go to every bay to power the timer and coin acceptor. The "common" needs to go to everything, every bay, one side of every solenoid, contactor, etc. The white wire is the common.
All those white wires should have a main lead back to the transformer, not to or through any breaker. Every bay wire should have the "common" connected to that same bus.
Kyle1
I’m getting 123v and 123 v on the top of the transformer
Kyle1
How it is going right now.
Main breaker- circuit breaker for the bays- TF: common-common blocks, hot TF- fuses- bay connection hot
Kyle1
I HAVE THE PROPER POWER TO THE BAY!!! However now my low pressure set up is kicking out water
That breaker is on the 240V side. It's there as a shutoff for the power TO the transformer.
What does "kicking out water" mean exactly?
Kyle1
Ok here is the update I have finished the wiring and plumb I have power going to the bay however I’m running into this issue of the rinse/soap isn’t coming out. Yes the solenoid is magnetized
Kyle1
That soap coming into the line was when I had the rinse on
There's an open check valve that probably should have water from your holding tank going to it. It looks like you have the line that should go to the inlet connected to the regulator. The rinse solenoid should kick in and deliver water on that selection, but the solenoid may be bad or not hooked up properly. I assume the pump motor is coming on when soap or rinse is selected?
Kyle1
Yes the pump motor comes on and that solenoid is good
Kyle1
Green going into the terminal strip and red going into common
Kyle1
So I’m at the point of countless hours and time away from my family no money coming in. I need a technician out of Florida to come in ASAP. Don’t care about travel time of cost of service at this point I just need help
Kyle1
I got it kinda plumbed out and I’m getting full pressure however now water is still not coming out of the gun and the pump is getting hot
