What product are you using? I like the bright green.customers are finding the tire brush!
How exactly did you set that up? Did you add boom, foamer or just gun? Id to to do this.We dispense KR tire cleaner through the 3x foam gun. Have attached a picture of a customer's wheel after they used it.
We already had the 3x guns with the booms, just added the manifolds on top that cantbreak80 said to buy and showed how to plumb. We have 3x, tire, and PS all coming out of the same gun now. No more tire and PS out of the HP wand, looks much better and eliminated a bunch of check valves which was GREAT!How exactly did you set that up? Did you add boom, foamer or just gun? Id to to do this.
What's the delay time when switching to a different product?We already had the 3x guns with the booms, just added the manifolds on top that cantbreak80 said to buy and showed how to plumb. We have 3x, tire, and PS all coming out of the same gun now. No more tire and PS out of the HP wand, looks much better and eliminated a bunch of check valves which was GREAT!
Haven't timed it, but a few seconds at most, the manifold is right above the boomWhat's the delay time when switching to a different product?
Do you have pix of the manifold setup?Haven't timed it, but a few seconds at most, the manifold is right above the boom
Took this idea from cantbreak80. Here is one of his posts on how to setup, he has a few if you search. We used similar units from Amazon with good results.Do you have pix of the manifold setup?
I'd love to do the same.
PS currently comes out of the HP gun and has an 8 to 10 second changeover.
How did you plumb all you products to get the fastest delivery/change over?
You could eliminate the check valves but I wouldn’t. The pump acts similar to a check valve BUT if the diaphragm gets weak it will allow the other chemicals to push back through the pump.Wondering the same thing, i have check valves. Do I need a check valve if adding tire cleaner to the triple foam gun. Right now i run tire cleaner through the high pressure gun when i move it to the triple foam gun do i need to run just product line or also a line for air now? 2 Lines
You mix 1 gallon of tire cleaner with 4 gallons of methanol. Car products which is a brand of chemicals distributed by Dubois makes an antifreeze tire cleaner.
Right on!new tire brush and 3x foam are very popular with customers so far.
