Reliably removing the eyebrow requires constant attention to 5 details. They are water quality, water temperature, chemistry, impingement, and dwell time. With a
touchless you can not just set it up and walk away. You must constantly check to make sure your draws and pressures are staying the same. These are the four setups that I have found solve the chemistry portion of the
touchless cleaning equation.
JBS Action Line
1st Pass - AT101 - Brown Tip
2nd Pass - AT102 - Red Tip
2nd Pass - AT150 - Pink Tip
This setup is good with water hardness up to 5 grains and then it falls off fast. Water temperature needs to be as high as you can safely run through your pump. This is a Lo/Hi setup that requires at least 10 seconds of dwell time after each soap pass to fully remove the eyebrow through out all times of the year. You can reduce the dwell time during periods of easier cleaning. This setup is easy on the equipment but can be slow to pass out through the reclaim. This is
JBS's most affordable solution but requires more time to work.
JBS COMPASS Line
1st Pass - CPS104 - Brown Tip
1st Pass - CPS105 - Light Blue Tip
2nd Pass - CPS200 - Red Tip
2nd Pass - CPS201 - Brown Tip
This setup is also good with water hardness up to 5 grains of hardness. Water temperature needs to be as high as you can safely run through your pump. This is a Lo/Hi setup that requires at least 5 seconds of dwell time after each soap pass but no more than 10 seconds to fully remove the eyebrow. This is
JBS's best solution needing less time and allowing for more control throughout the year. This setup is slightly more aggressive yet still easy on the equipment allowing for limited down time. It is more expensive though.
Auto Lux Line
1st Pass - HP640 - Tan Tip
2nd Pass - AL-10 - Red Tip
2nd Pass - ALTP1200A - Burgundy Tip
This setup requires 0 grains of hardness. Water temperature should be between 119 and 115. This is a Lo/Hi setup that requires 10 seconds of dwell time after each soap pass to full remove the eyebrow. This is the most cost effective solution but it is slow and requires constant attention to the your water quality. This setup is very easy on the equipment allowing for less downtime and works well with reclaim.
CSI Lustra Line
1st Pass - 224 - Turquoise Tip
1st Pass - 515 - Turquoise Tip
2nd Pass - 205 - Turquoise Tip
2nd Pass - 715 - Orange Tip
This setup requires less than 4 grains of hardness. Water temperature should be between 105 and 115. This is a Hi/Lo setup that does not require dwell time after the passes. This setup will require more maintenance to your equipment. It is expensive but fast and leaves the vehicle with a final pH of 6.8 which is ideal for waxes and
drying. Unlike most of the other presoaks on the market this one uses a special surfactant that breaks the oil film almost instantly. This requires getting the film moving before the surfactant evaporates and the film resets. If you can afford to run it this is the ideal soap setup for your Petit.
All setups have been tested for multiple years in a southern market with petroleum products being burnt off and creating heavy coatings of oil on the local vehicles.
