Unitec Select Wash II Help
bige18675
I have a Unitec Select Wash II go down. The Display Board isn't showing anything and I've changed it out to test with another unit. I do have power going to the unit. Anyone know any tech in North Houston that could possibly help fix this problem.
bobcat9095
Are you talking about just the main display at the top of the unit? That says "Please select a wash" etc?
bige18675
Yes. I replaced the main cpu board on the inside and fixed that problem. Now it wont stack the washes. This unitec is running a water wizard 2.0
bobcat9095
Sounds like a programming issue. Do you have an operations manual? If not, you can download one from Unitec's website. You can also set up a time to talk to a tech if you need.
