- Joined
- Aug 31, 2007
- Messages
- 6,211
- Reaction score
- 792
- Points
- 113
I understand. However, not all photo cells are made equal. Cheap ones like the kind HD sells ain’t worth a damn. They do everything you described and cannot be adjusted. I use photo cells for my exterior lighting. I purchased some from a local electrical supply that were costly but have a cover on them that you can slide down over the photo eye if you want the lights to kick on sooner. If there is a HEAVY overcast they will still kick on which I don’t have a problem with that. I want my lights on when it’s cloudy out. That’s just my personally preference. Astronomic timers are also a great option.I've struggled with photocells at car washes and have never found a unit/setting that works the way it should. It will either come on too late and the bays will be dark for 20 minutes at sunset of the lights won't go off or will come on if it's overcast. I won't ever use anything but an astronomic timer again.
Why don't you like to light bays in bad weather? Because of money? If thats the case, LED Lights practically cost nothing to run. Very very rarely do I get someone trying to work on their car in a bay, definitely not enough to justify cutting my lights off for the whole wash during overcast days when its dark out. IMO washes feel safer for customers and are more likely to drive away thieves/vandals when the wash is lit up.I have always used the good ones. I don't want the lights on all day if it's raining. If you set an astronomic timer to come on 20 minutes before sunset, the lights will always come on and light the bays when you need them lit, and you won't be lighting bays in bad weather to encourage mobile mechanics.
Money and lifespan of the lights themselves, as well as people loitering to use the lights in bad weather. If I don't run off the loiterers, it gets worse and worse. During the last extended rain I had people setting up tents in the bays.Why don't you like to light bays in bad weather? Because of money?
I get it all the time, and the lights encourage it. The roof is high and open enough that it's not excessively dark in the bays no matter how overcast it is, but even then I don't get much washing except for engines and truck beds.Very very rarely do I get someone trying to work on their car in a bay
FWIW, I have used Home Depot photo eyes for 2 decades with tremendous success.I understand. However, not all photo cells are made equal. Cheap ones like the kind HD sells ain’t worth a damn. They do everything you described and cannot be adjusted. I use photo cells for my exterior lighting. I purchased some from a local electrical supply that were costly but have a cover on them that you can slide down over the photo eye if you want the lights to kick on sooner. If there is a HEAVY overcast they will still kick on which I don’t have a problem with that. I want my lights on when it’s cloudy out. That’s just my personally preference. Astronomic timers are also a great option.
That style is not sold at my local HD or maybe I just did not see them when I was looking years ago. The ones I tried from HD did not have that option. I would wrap half the lens in black tape a few times to get them to come on sooner. After a year or so they would die and lights would either not come on or stay on all they time. I’m glad you’ve had some success though!FWIW, I have used Home Depot photo eyes for 2 decades with tremendous success.
That little metal tab isn't a mistake, it's the adjuster. Lights don't come on soon enough? Move the adjuster over the eye a little bit more until they come on at the desired time. What could be easier?
(And of course, make sure the eye faces south...)
I've had success using those as well. Got mine at Lowe's. Replaced a timer with one of these.FWIW, I have used Home Depot photo eyes for 2 decades with tremendous success.
