Buckeye Hydro
Can you physically lower the entire pump so you can take advantage of more of your tank volume?
Finally got to work on hooking up the delivery system today. I can’t seem to get the pump to prime. Does anybody have any pointers. The pump kicks on but there’s no water flow.
Is it normal for the system to still have pressure on it after it’s kicked off?
Always good practice to do this.Should I install an overflow protection at the top of the tank that plumbed into a drain in case I have a float malfunction?
