Secret to putting push-lok fittings on
APW
Southeast
After putting eight fittings on tonight I am give slam out. There has to be a secret or easier way or do they make a tool to do this?
MC3033
Midwest
What kind of push lock fittings are they? What type of material?
I’ve never had an issue putting one on. Taking them off is another thing
Lexington, Ky.
I put on 4 the other day and bruised the crap out of my palms. I put some cutting oil on the fittings first then press and turn, but it's still hard.
  • Like
Reactions: APW
APW
Southeast
They are Parker push-lok. The hose is a rubber continental for low pressure.
Hot water. I keep an old saucepan at the wash and heat a couple inches of water with a torch to almost boiling. Soak the hose in it for 15 seconds and it'll slip right on.
The local Parker distributor makes hoses to order and they said use alcohol as a lubricant along with a special device to force the hose over the fitting. $400 later and we had about 12 hoses assembled and a bent handle on a machine we could no longer use.
pgrzes
S.E. Pa.
We will usually use a little heat in the winter time. I always use the wood on the end of a bench or stair rail and put the fitting against the wood two hands and my beer gut, spit on it and slam it in there wiggling back and forth a bit. Works pretty well on up to 3/4" stuff. Never had a complaint!! Bigger stuff gets tough! Might need a better lube and more foreplay I mean heat!! Thats how the person at our local hose shop showed me how its done! I wont say if they were a he or a she!! LOL Enjoy.
The 3/4" and 1" push lock fittings are really tough. New hose in the smaller sizes is not too bad, but once it gets old and stiff it becomes extremely difficult. I have done the hot water method and carry in a thermos for a few fittings when I'm anticipating doing a couple. I'm tempted to buy the hose press, Jegs sells it and you can get discount coupons if you're patient. I'm about to rehose a water wizard and there's tons of push lock fittings on them.
Ok, how do you take them off?
You have to cut the hose, which you have to do carefully if you plan to reuse the fitting. I prefer to cut a slice off the side of the hose, cutting toward the yellow ring, and only cut through the nylon reinforcement, then bend the hose to the side and it should slip off. If you just cut into the hose with a sharp blade and score the barb, it will leak.
I use push-lock fittings with polybraid hose all the time whenever there's no pressure on it. It's a lot less expensive, and a lot easier to get the hose on. Kleen-Rite sells it in several colors which for some reason is even cheaper than the clear.
