Scott.Downey
- Joined
- Jan 5, 2022
- Messages
- 102
- Reaction score
- 24
- Points
- 18
The folks who are using nayax ,do you just enter a dollar amount you want to use and then unit counts down or is able to be configured to count up?
I would not assume that. He said there's a configuration in the timer, presumably to match the count-up from the Nayax. Dixmor LED-6 doesn't have that.So I'm assuming that a dixmor led 6 would configure with it and count up.
For Nayax VPOS count up with a Dixmor LED6 at $3.00 to start/3 minutes…So I'm assuming that a dixmor led 6 would configure with it and count up. I had talked to a rep yesterday and he was unsure about count up abilities, someone more familiar with the wash nayax was going to call me Monday.
Thank you for your detailed explanation. Are you a wash owner with nayax in service?For Nayax VPOS count up with a Dixmor LED6 at $3.00 to start/3 minutes…
Program the Dixmor with:
COIN VALU [$ .25]
C: [15] (This is time per coin pulse)
S: [12] (This is coins to start)
CC PULSE VALUE: [$.25]
DOLLARS ON COUNT UP
Connect Nayax VPOS Pulse Wire #1 to Dixmor Pin 8 (White with Black Wire)
Now, the Dixmor will display dollar amount charged to credit card as it accumulates…just like a gasoline dispenser.
Verify the settings by swiping/inserting/tapping the credit card.
The LED6 should continuously display money charged to credit card. At 1 minute the timer should display $1.00…at 2 minutes the timer should display $2.00, etc.
Thanks for the detailed info on this, we are getting ready to install led 6 timers and nayax in the bays. Quick question, can the min charge be setup different for cash and credit? Ie $3 start for cash and $5 min for cc?For Nayax VPOS count up with a Dixmor LED6 at $3.00 to start/3 minutes…
COIN VALU [$ .25]
DOLLARS ON COUNT UP
Thanks, makes sense now.Program the LED6
With coins, this starts the bay for $3.00 for 3 minutes. Each additional coin adds 15 seconds.
During credit card Count Up, the Dixmor simply displays accumulating money being charged.
The CC Minimum charge is established by your Nayax configuration…say $5.00.
So, CC customers who press STOP before 5 minutes of use will still be charged $5.00.
I believe you'll still need a timer for the vacuums. (I've no experience there)
It doesn't.I have one on the bench getting ready to install...I assumed that it didnt need anything to communicate with my dixmore 6
Someone is confusing count-up and count-down wiring. You do need a relay to run count down.Our installations do not use any relays. I’m not sure why Nayax recommends them.
Huh...I didn't know that.Someone is confusing count-up and count-down wiring. You do need a relay to run count down.
Hi Mep,Someone is confusing count-up and count-down wiring. You do need a relay to run count down.
