How can I set up my prep guns to turn on/off with the gun trigger?
It's simple to do - there's an inline flow switch you would install downstream of the unloader along with city pressure to activate the switch when the trigger is pulled, then run power from that to an off-delay relay. Like Washmee said, you probably don't want it starting/stopping every time, but with a delay you can control it to stay on between cars on a busy day.
Thanks. Do you have a link to that flow switch?
I've installed the Suttner ST6 on equipment and had no complaints about it.
