Prep gun setup
Ric
Cantree Member
West Michigan
How can I set up my prep guns to turn on/off with the gun trigger?
TEEBOX
Detroit, MI
Ric,
Contact Powerbrite in Livonia MI, 734.591.7911 and Ask for Don Kleemer. Mine come on that way. He can help!
Good Luck.
Washmee
Fullservice Tunnel
Canton, Ohio
I don't think you really want to have your guns turn off every time you let go of the trigger. Most setups use a flow switch to activate a timer which turns the guns on and then shuts them off after a short period of time.
It's simple to do - there's an inline flow switch you would install downstream of the unloader along with city pressure to activate the switch when the trigger is pulled, then run power from that to an off-delay relay. Like Washmee said, you probably don't want it starting/stopping every time, but with a delay you can control it to stay on between cars on a busy day.
Ric
Cantree Member
West Michigan
Thanks. Do you have a link to that flow switch?
I've installed the Suttner ST6 on equipment and had no complaints about it.
You have to use a non-weep, which also means you'll need an unloader.
