PLC issues
LBF Carwash
I have an omron cpm1a and it keeps blowing fuses inside of it. The supply voltage is working and at the correct voltage, is the power supply board bad? Any help would be helpful!
eckert16
...CA VA OH PA
Track down the manufacturer of your carwash equipment (PDQ, WashWorld, etc) and they'll likely give you a distributor that can replace it for you on site or the equipment manufacturer will ship you a replacement.
Someone can also download your current PLC program (if it is not locked), store the program, remove and replace the CPM1, and reload the program to the new PLC.
LBF Carwash
Ok thank you for the help!
