Petit or Oasis distributor
Dwell is an absolute must with the typhoon or it will not clean. It is too fast. Typically I set up top washes like this:
PS1 Pass
Dwell Pass
PS2 Pass
Dwell Pass with UB
Rocker Blaster Pass
HP Pass
Triple Foam Pass
HP Pass
Rain Bar Chem Pass
HP Pass
Rain X Pass
Med Pressure HP Pass
HP Wax Pass
Spot free Pass
All that in three minutes. Basic washes are around 1 30 sec. You can layer the chemical on and do a top washes in 1 30 but that’s not the right way to do it and customers will probably feel like they are getting ripped off.
How much water are you using with all these HP passes? Seems like a lot of HP passes.
You could definitely do less passes but I don’t want the wash so quick that a customer does not feel like they are getting their moneys worth. I also like to start my chemicals front to back.
That is the top wash and I would guess probably about 14 gallons a HP pass. Passes are only about 10-15 seconds long depending on the vehicle.
If you really want to know I can turn my float off tomorrow to get an accurate number.
