No soap in one bay
Tbone777
Can someone tell me why the system lost the draw on the soap line. I removed the 1/4" line from the flow meter so it could draw directly out of a small container of water. The line was from the container to the manifold with the three 1/4" lines. No suction from the manifold. Please help a new owner. IMG_2984.JPG IMG_2984.JPG
Might be another check valve issue. Is it just soap, or does it also not draw wax?
Did you ever solve this problem?
Tbone777
Have everything going now. Both problems solved with check valve replacements. Thank you all for your advice.
