When below 32 degrees trolley stops half way across front of car. Cycle 1 bridge move time out is message. Have changed oil and added a heater stick to gear box but still aborting washes when cold.
Since your tires are good, you may want to check the wiring harness in the e track leading to the trolley. I had the same issue awhile back and it ended up being the power wires coming apart from the constant bending. I was able to see the insulation deteriorating and exposing bare wire.
