LW turning too early, when coming up
2 of past 4 days, my LW has turned too soon , when coming up passenger side, & impact shuts it down.
Any advice?
PEI
Danville, VA
Does it have a Virtual Treadle? What software version are you running?
Has VT, but can't remember the version. I am stuck at school all day, then away bb games tonight.! My employee is going by after while...
Mansfield ohio
i had the same problem last month
i thought the home flag 30mm was going off and tricking the machine
so i changed that and the festune wire
still did it
so i changed the front eye still did it randomly
so i put the amp on the rear eye and it guess what starting turning early on the back
try the x40 amp in the j3
for a quick check just swap the two out and see if it follows to the rear eyes
good luck
will look at it this afternoon. bad weather, so not missing biz right now
No, it goes across the back, then turns early, to go up passenger side. It does seem to turn, to go up, about the same area though...
Mansfield ohio
Mine did that awhile back but was on the front
my impact switch would shut it down
and i noticed the left limit eye was on, it was really cold that day so i wiggled it and then actually hit the back part of the plug with my wrench and it went off..........so anyways bad eye
next time it happens see if your right sensor is on in gantry or in jo
good luck
Not yet. PDA told me to change out trolly relay, 24v. So I ordered that yesterday. STILL RAINING here in E Tx!!
What's your thought on trolly relay?
tried trolley relay. Not fixed. I am calling Twin Distributing, my distributor. MFR!!!
bryan church
upstate NY
Check your x30 prox, if it's damaged, replace it, replace the x30 prox cable, also check for a bad connection and corrosion in the junction box. If you still have an issue, you may have a bad wire in your festoon cable. Good luck..
Bryan was correct. 30x prox sensor was worn on front. Prolly gonna be $350 for using Distributor
