OK guys, you know Murphy's Law affects carwashers too. At my wash high pressure hose breaks happen most often on the weekend. In an act of desperation to keep a unit running I discovered this technique a few months back. It actually works so well I thought I would share this with you guys. You may laugh when you read this, but don't knock it until you've tried it. I have patched hose this way and the result is 90-100% reduction in leakage and the patch will last for months. I'm not advocating these as long term repairs, but it certainly will last long enough that you can order the proper replacement hose from a mail order house. It works best on straight runs but will work somewhat on gentle bends- enough to keep running.
OK, so we have a leak here on my undercarriage hose:
Dig through your garbage can and find a uncrumpled, smooth aluminum can and remove the top with a razor knife. "unwind" the can into about 3/4" thick strip:
What you will end up with about a 4' long strip of malleable thin aluminum:
Wrap aluminum can snugly around break a couple of times, then begin to work outward on both sides of the break, overlapping tightly so the aluminum is about 2" wide:
Secure with three quality hose clamps tighten the center one over the break, then put a clamp on each side, as close as possible to one another. It is preferable to have their sides touching. Re- tighten each clamp a couple of times.
And that's it. Like I said, it looks bad but works much better than I imagined. I have been able to completely stop leaks in 1" hose with this. It's works so well, an empty aluminum can is now part of my toolkit.
