For the one that runs the trough heat I put a T on the return side with a Valve then came off the valve and went up and then increased the inlet side to 4" using PVC. With the circulater pump running I simply would pour in the AF mixture. It would suck in the mixture and air could escap thru the same area as well. There is an expansion tank as well. You need to have one .Hi there i was wondering what is the best way to fill a waterheater with Anti freeze .
can i buy a manual pump
Tryed the pump drill did not workIf you are looking for inexpensive...
http://www.lowes.com/pd_138026-1564...=pumps&page=1&Ns=p_product_price|0&facetInfo=
ok will do thanksYou would be better off adding the information to the thread you have going already so people will know everything that has been going on.
i had a mechnic come in today you where right i had to reset the water heaterDid you check to make sure that the reset button on the hot water tank wasn't tripped?
