C cleancar New member Joined Apr 7, 2013 Messages 10 Reaction score 0 Points 1 Location lititz May 17, 2015 #1 I am having an issue with high pressure. When the pump is on high pressure with out the trigger being squeezed, the psi is 1550. When the trigger is squeezed it is 1110. Whats the problem? I checked the belts and they are tight enough.
R Randy Well-known member Joined Sep 5, 2007 Messages 5,691 Reaction score 1,992 Points 113 May 17, 2015 #2 You've got a problem with the pump head. I've got the same thing going on, I need to replace the seals. You could have worn out seals. A bad valve or a bad regulator.
C cleancar New member Joined Apr 7, 2013 Messages 10 Reaction score 0 Points 1 Location lititz May 17, 2015 #3 Thank you very much
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,939 Points 113 Location Texas May 18, 2015 #4 Check the tip in the bay. They should be changed every 2-6 months depending on how much the bays are used.
