Is this a new style goldline? (the one that has to have the handheld programmer to program all settings). If it is, then yes Cryptopay and the Goldline don't work quite right all the time. they lock up and have to be reset. I sold two new goldline autocashiers last year. we ordered them without credit card, then installed cryptopay. Every so often they lock up and say "purchase is complete". These units are installed 90 miles apart from each other. one is connected to a
razor and one is connected to a D&S 5000. same issue at both locations.
I was kinda dissapointed in Hamilton with their new style Goldlines. You have to use a credit card handheld programmer to set them up. They also changed all of their programming terminology, so it was confusing to program. They also did not have a manual for these units at that time (one unit came with a older goldline manual that said to use the buttons on the controller, and one came with an htk manual???) so took phone calls to them to set up initially. Plus, you could no longer get access to any counts from the goldline. Hamilton said they were still working on that.
To be fair, Hamilton did take all the calls from my customer and myself on this "purchase is complete" message problem. they started several case studies for my customers to help identify the problem. Hamilton was a little "stand-off ish" because cryptopay was installed on these units, but not to the point where they wouldnt help us. Their customer support is really top notch for our industry and i do appreciate that, even though i was dissapointed in these goldlines.
Anyway, sorry to be off topic a little. At one location, Hamilton had the customer change a setting that, to my knowledge, has eliminated their "purchase is complete" problem. or at least it has covered up the problem. Supposedly Hamilton set the Goldline to reset itself every so often. Not 100% sure but it might have been a drive off timer setting. and i also have a note about unplugging #18, but not sure what that means. maybe this can help you .
