Correct Dilution Ratio for Soap and Wax?
wrightwash
Middle Tennessee
I’m finishing up renovations on our new car wash. I’m trying to get the proper ratio of HP Soap and Wax. Right now I went by what is shown on Kleen Rite for tip sizes. While I can see some soap it just doesn’t seem like much. If I was a customer I would definitely want to have more soap. Also, I barely see the wax. It definitely is not “foaming”.
I’m guessing by teeing into the main suction line I’m diving my dilution ratio by half? So do I need to double my tip size?
For Soap:
Simoniz Body Bath HP Soap
Calls for 600/900 to 1 Dilution
506 Hydrominder with Purple Tip mixing into a 15 Gallon Tank
Tank connects to a KIP Valve, 1/4 line from valve tees into the 1/2” main suction line on pumps.
For Wax:
Simoniz Blue Magic Foaming Wax
600/900 to 1 Ratio
506 Hydrominder with Pink Tip
15 Gallon Tank connects to a KIP Valve, 1/4 line from valve tees into the 1/2” main suction line on pumps.
Why are you using a 30 gallon chemical tank, I use a 4 gallon tank. I’d go up to a Yellow tip and then a Brown tip if I didn’t like the show on the High pressure soap and on the wax I’d go up to a Purple or a Yellow if I didn’t like the show. You have to just play with the tips until you get it to where you like it.
wrightwash
Middle Tennessee
You made me second guess my sizing. I checked they are actually 15 gallon. My main rinse tank is 30 gallon.
