I am installing a new 2 pole contactor. The new contactor is the not same size, so I will need to drill new holes and mount it on the back panel. The problem is I do not want to remove the back panel because of all the wires I will need to remove. Can I just use a small metal tap screw and drill it threw the panel instead of using a screw and putting a nut on the back panel?
Any ideas will be appreciated.
