zathura21
I bought by 4 blower from Kleerite ( Air Shammy 2) and all the stuff that you recommended.
Now I am working with local electrician and technician to get it all hooked up.
Will send you picture, when its done. Thanks a lot
Excellent! We love to hear updates, see photos & celebrate your success!!I bought by 4 blower from Kleerite ( Air Shammy 2) and all the stuff that you recommended.
Will send you picture, when its done. Thanks a lot![]()
duct tape. I don't want them too secure - in case a car hooks them I'd rather have the hose come apart than pull a boom down.My hoses keep disconnecting/falling out of the swivels on the booms. Does anyone else have this problem? Do you glue them, screw them, etc to the swivels?
That was my concern with screwing them. I’d much rather lose a hose than a boom. Not sure if the hose would tear if a car hooked it or if it would damage the boom?I use
Duct tape looks so temporary & trashy. We secure with 4 screws. When a customer snags the hose it unravels at the boom. The hose is made of plastic & the weakest part. The boom won't fall.That was my concern with screwing them. I’d much rather lose a hose than a boom. Not sure if the hose would tear if a car hooked it or if it would damage the boom?
Curious if that wire is to actually to provide support for the hose, keeping it from stretching overtime as it gets hot and the plastic weakens.Hi, it's Nick again,
Hope you are all doing great!
I've read a few things here and there and wanted to check them with the forum.
- In the mosmatic hose, there is a wire attachment that runs through the hose (see picture). I'm not sure what it does. Maybe it's some grounding for static electricity. Any ideas?
- I read in a Facebook post somewhere, where similar blowers were used in a different industry, and the guy explained that this blower must be used with a vacuum filter and release valve (see picture). Is anyone using those?
Thank you in advance!
Agreed.
When we had them inside the bays, one issue we had sometimes was birds building nests on top of the motor. They have plenty of air flow. The motors are in our attic now that we have an attic. If I had to have them in the bay again, I would consider installing hardware cloth to the insides all the way around to fill in the gap from the cover to the wall.Hello,
I was wondering if you put a cover on the AirShammee 2 engine, you know the boxy thing that covers the whole motor, does it interfere with the air supply of the machine? If there is someone that got his engine covered and wants to share his/her experience.
