Air logic or Air shammee
Who do you buy your soap from? Here in Northern California, my soap rep company contracts with a sub-contractor who installed the Diskin dryers for me. You can also hire a qualified & insured handyman / electrician to do. Follow the tips given in this Forum.
I bought by 4 blower from Kleerite ( Air Shammy 2) and all the stuff that you recommended.
Now I am working with local electrician and technician to get it all hooked up.
Will send you picture, when its done. Thanks a lot :)
Excellent! We love to hear updates, see photos & celebrate your success!! 👏🤩
My hoses keep disconnecting/falling out of the swivels on the booms. Does anyone else have this problem? Do you glue them, screw them, etc to the swivels?
I use
duct tape. I don't want them too secure - in case a car hooks them I'd rather have the hose come apart than pull a boom down.
I use
That was my concern with screwing them. I’d much rather lose a hose than a boom. Not sure if the hose would tear if a car hooked it or if it would damage the boom?
Duct tape looks so temporary & trashy. We secure with 4 screws. When a customer snags the hose it unravels at the boom. The hose is made of plastic & the weakest part. The boom won't fall.
Hi, it's Nick again,
Hope you are all doing great!
I've read a few things here and there and wanted to check them with the forum. :)
  1. In the mosmatic hose, there is a wire attachment that runs through the hose (see picture). I'm not sure what it does. Maybe it's some grounding for static electricity. Any ideas?
  2. I read in a Facebook post somewhere, where similar blowers were used in a different industry, and the guy explained that this blower must be used with a vacuum filter and release valve (see picture). Is anyone using those?
Thank you in advance!
Curious if that wire is to actually to provide support for the hose, keeping it from stretching overtime as it gets hot and the plastic weakens.
On another note, last year I had one of my motors suddenly stopped working and diskin sent me a new one because it was under warranty. I took the old one apart and started investigating no surprise to me the motor is made in China. I began digging around online and found the exact motor on Alibaba. Ordered several of them and sure enough it is the exact same motor diskin sells. with shipping bought 2 motors for $600 via Alibaba.
Someone recently posted here that Air Logic was recently bought out. I would call KR and find out if they can still get the nozzles from Air Logic. I hope they don't discontinue them, they work the BEST with Diskin's Air dryers!
Agreed.
I recently spoke with Seth and based on what he said, I wouldn't expect to see anything from Air logic on KR's platform again.
(This was my interpretation and don't want to start or stoke anything:rolleyes:)
However, it seems to be a pretty obvious extrapolation of where a business owner's mindset would be after supplying a manufactured product for years and then they cancel you and start making their own product almost exactly the way you were.
Hello,
I was wondering if you put a cover on the AirShammee 2 engine, you know the boxy thing that covers the whole motor, does it interfere with the air supply of the machine? If there is someone that got his engine covered and wants to share his/her experience.
Diskin's dryer motor cover brackets allow for cover to sit about 3" - 4" away from the wall, all the way around. Air flow is sufficient!
The original covers came with an open hole, that I covered with a SS boat vent cover, to help protect the motor from direct spray. The new covers no longer have this hole.
Hello,
When we had them inside the bays, one issue we had sometimes was birds building nests on top of the motor. They have plenty of air flow. The motors are in our attic now that we have an attic. If I had to have them in the bay again, I would consider installing hardware cloth to the insides all the way around to fill in the gap from the cover to the wall.
