I have had an intermittent issue with the wsII resetting anytime the cube dispenses quarters. I say intermittent because it will work fine for a week then out of the blue the calls start rolling in. Takes the money- no change - no wash. The whole unit turns off and back on in 1 sec then shows the software version, date etc.. It works perfectly as long as the customer uses exact change or cc. I have replaced the hopper and wiring with the same result. I had the same exact problem 1 yr ago anytime the speech option would come on and had to replace the 5v ps1100 power supply. I was told to install new power supply again and if that doesn't work motherboard! Feels like I'm ****ing in the wind
Is it possible something is causing my power supplies to burn out? Power spikes/ surges.
Seems strange to have two power supplies to burn out in under a year
The unit has been in service for 13 years and has 5.33 software
Maybe it's time for portal
