Thanks for the quick response. It is an older fragramatics fragrance vacuum. It currently hat the little two timer display timer that is bad. I can not find a replacement so was told I could use a Dixmor LED 6 or LED 7.
I compared the two wiring diagrams but the little two timer has wire #4 grey-two time select wire and I am not sure where it would wire to on the Dixmor timers.
Also do you know if the LED7 is multi function? It does not appear to be to me.
LED7 is not a multifunction. LED6 will not work in a fragrance vacuum. LED6 needs momentary contact buttons to switch functions and won't work with the toggle switches. Call Fragramatics, they might be able to get you a repaired timer.
OK, I did this a year ago but I'm already rusty so maybe Miles can help me out. I installed LED 7s and 9s on some fragramatics combo vacuums in place of the IDX Timers. The LED9, a big timer, could do up to four different price points but can not change/time price on credit card count up, which is what I want to swap to. The LED 7 has one price point but my fragrance and shampoo usage is so low I didn't care and will sell that service at the same price as vacuum time. I plan on retrofitting the next group of combos vacuums with LED6 timers, strictly for the count up in cash feature. That way it will eliminate confusion on the property (current setup is bays count up and display cash, vacuums are count down). I feel any decrease in revenue from a reduced price on shampoo or fragrance will be more than offset by less customer confusion and switching to count up cash on vacuums.
Dixmor would not provide information on rewiring but it's pretty simple. One thing I remember was that you need an extra wire and 12V horn for the dixmor as the IDX uses a 24VAC horn.
AFAIK, there's no way to get different price points with the LED6 and credit card with count-up. It can display the cash spent, but the CC system has no way of knowing or changing the time per money spent. FWIW I have successfully wired a LED6 into a Fragramatics fragrance vac and everything worked, but I was handed a timer, harness, and a very rough diagram. I had to touch bare wires to make it switch between fragrance and vac since the timer is made for buttons and it doesn't change function until the button is released, and there was some other issue I don't remember now that made the customer decide to just put an IDX timer back in it. It might have been that he wanted the LED6 so his Cryptopay could count up and charge different amounts which it can't do, I know that was at least part of it.
