Weep check valve on bay 2 is most likely the culprit. Unhook the bay 2 line from the weep manifold and push in the pump contactor. If water comes out the unhooked line, the CV is bad.
I agree, it's bay 2 check valve
You can usually just open it and clean it and reassemble it (maybe even stretch out the spring in it a little)
it takes just a little something to get caught there and keep it from sealing
Any other things to check? I have the same issue on new SS equipment. My weep system has a water shutoff value to the weep system as well as to each bay. The valves are off yet a bay seems to weep. Thanks.
Honestly, I bought an old, poorly maintained SS and I have replaced or rebuilt everything, this has happened many times to me and it’s always the backflow preventers. I guess the weeping is from this not your weep system for freezing
