What did I fry?
Bricks
Goldline with crypto. The tapper had been hit or miss and the swiper seemed to be jammed up. Put new of each on today and now it only takes cash.
Cryptopay sees the transaction, but the wash will not start.
Sounds like your red/greens aren't where they should be.
The newer swipers and taps have two red/green wires for the signal wires.
If you have older swipers they have black, yellow, blue and red wires.
That with the knowledge of the timer type will help you get this wired up correctly.
These were both newer types. I’ve talked to Hamilton, cryptopay and a few distributors. The handheld will not work. Tried two and neither would power on
The EIC was not plugged into the distribution pan. The plug was tucked away hidden. I don’t know why this was needed or why the last owner unplugged it. It has always been dependable during my 4 years of ownership.
I’m thinking about unplugging it just in case.
A few times after I was finally up and running, it would say “purchase complete “ as if it’s clocking more than one swipe. I powered it off for 30 seconds. Hopefully that gets it.
Does anyone have a list of key settings for these? I may have messed something up when desperation set in and started pushing buttons.
24hrs of a wash being out of service will make a guy crazy. You know? $5000/month wash payment in a small town makes every day count.
Ive been having issues getting my goldline plus setup for crypto and hamilton said basically it will not work without the crypto display, wonder if your display is bad.
The display is what talks to the swiper. You absolutely need it if you want to use Cryptopay. The gold line plus got the small screen so yes that wont work. What credit card reader is currently on your good line plus? Why do you want to change it?
Yes thats what they told me, idk somekind of insert reader. Why? Because im adding crypto to all my bays and vacs, why would i want that one to be different.
Not that you have to worry about it because you can’t do it but for one most importantly you would lose hosted solutions and two every customer will see a $10 pre auth charge instead of the wash price they selected which leads to plenty of phone calls and bad reviews.
