W WallyBalls New member Nov 22, 2021 #1 I need a few of these but have no idea what they are called or where I could get some for both 1/2 and 3/4 pipe Attachments 67C8F3A9-9902-4A19-8E61-3C12A5AECC4D.jpeg 1.6 MB · Views: 59
G GoBuckeyes Self-Serve and Automatics Nov 22, 2021 #2 Didn’t pay attention to your size but this will get you to where you need to look. TeeJet / Spraying Systems Check Valve Nozzle Bodies, Top Style: QuickJet x 1'' Pipe - Dultmeier Sales TeeJet / Spraying Systems Check Valve Nozzle Bodies, Top Style - QuickJet x 1'' Pipe, 2.25 GPM;Standard Check Pressure is 10 PSI (2, 5, 8, 15 & 20 PSI also available);300 PSI Maximum Pressure.;Viton www.dultmeier.com
W WallyBalls New member Nov 23, 2021 #3 GoBuckeyes said: Didn’t pay attention to your size but this will get you to where you need to look. TeeJet / Spraying Systems Check Valve Nozzle Bodies, Top Style: QuickJet x 1'' Pipe - Dultmeier Sales TeeJet / Spraying Systems Check Valve Nozzle Bodies, Top Style - QuickJet x 1'' Pipe, 2.25 GPM;Standard Check Pressure is 10 PSI (2, 5, 8, 15 & 20 PSI also available);300 PSI Maximum Pressure.;Viton www.dultmeier.com Click to expand... Thanks you very much. Sometimes I just need to be pointed in the right direction.
M Markkkk New member Nov 23, 2021 #4 Oh! I also do not know what's this. ABB HMI CP430BAnd anyone else could know it?
MEP001 Well-known member Nov 24, 2021 #5 Markkkk said: Oh! I also do not know what's this. ABB HMI CP430BAnd anyone else could know it? Click to expand... Perhaps you could read the description in your own link.
U UtahYoutubeGuy Active member Nov 24, 2021 #6 Markkkk said: Oh! I also do not know what's this. ABB HMI CP430BAnd anyone else could know it? Click to expand... This guy is posting suspicious links across multiple forums
