A customer , evidently with a tall vehicle, ran into my dryer bending the shroud. It is an ocsillating shroud. Of course it made one heck of a racket , so I removed the screen and funnel so I could take off the impeller, shroud, etc and hopefully straighten it all out. Thats when the first of two problems arose. When I tried to separate the inpeller from the split taper bushing, the flange where the jacking bolts screw in broke. The sleeve is still on the shaft but no way to separate the impeller from the sleeve of the taper lock bushing. I figure I will call the manufacturer and just get some new parts, right? WRONG...They no longer make this blower and they are no longer in business. Soooo..no parts available. I can get the taper lock bushing from Grainger, but I will still need the shroud, impeller and all the hardware that it rides on to ocsillate. There is not enough clearance to use a hammer to drive the impeller off of the bushing. Any thoughts?
