Weepmizer output 2
lighthousecarwash
I have a foam brush changeover system that is connected to the second output on my weepmizer. For some reason when the temps fall and activate the output, they climb above the 36 degree threshold, it does not turn off. It keep the output held on and I’m blowing through winter foam brush soap because it’s not turning itself off. I’ve compared all the settings with my other locations and it all looks fine. Has anyone had similar issues? Should I look at temp sensor or the unit itself? The temp always is consistent and correct.
Thanks,
Lighthouse
Do you have a relay between the Weepmizer and the foam brush changeover system so there is little or no load on the weepmizer? Or you could have a bad relay inside the weepmizer.
What does your foam brush changeover system consist of?
It has a time delay relay that operates a NC and NO Dema valves and then triggers a purge cube in each bay.
