Weep system plumbing help please.
APW
South
The solenoid on this is wired to the summer/winter switch.
Does the gray hose and the blue hose
on the right hand of the solenoid hook to my water supply?
And can someone explain how this works?
So you have 5 bays you weep all blue and the water line in grey. The weep controller turns the water on and off.... Via the solienoid valve.
When Buzzie8 says "save $$$" he means the Weepmizer will pay for itself in a month..... no joke. Well at least around here. :)
APW
South
it is a weepmizer. It is also a 4 bay ss.
Well if you have 5 blue hoses coming off that.... you probably have brush weep and another manifold?
APW
South
Thanks. I figured out the 5th hose goes to my triple foam.
