trinityspeedwash
Got a new issue that I discovered today. Customer had selected "Wax" from the dial, which engages the high pressure pump.
- Video attached shows the pulsating pressure.
- Setting at "RINSE" and everything works great at 1200 PSI
- Setting at "SOAP" and everything works great at 1200 PSI
- Another bay, set to "WAX" also has the pulsating issue.
Does this imply air getting into the system? The pumps run from the gravity fed Coleman that supplies the same feed for RINSE and SOAP, so I don't think it is a feed issue.
Any thoughts?
Any thoughts?
