toddmullens
I have about 14 of these units in operation and I am having an issue from two or three of them. These units are holding pressure after the pump turns off, which is causing the pump to start under a load at times. I have installed an “off delay relay” on the top spray boom solenoid to keep that solenoid open for a couple seconds after the high pressure pump turns off and that seems to have fixed the issue for the most part. Now it only does it after the undercarriage turns off. What’s strange is that it doesn’t do it on the rocker panel function, only the undercarriage and regular hp rinse function. I know the rocker pane uses a bigger solenoid and undercarriage, side spray, and top boom spray all use the same type of dema solenoid. I have replaced all the high pressure solenoids and unloader (I made sure the check valve was removed from unloader) and still had the same problem which is why I installed the off delay relay on the top boom spray solenoid just to relieve the pressure aa much as possible. I can’t understand why some of these units do this and others don’t. They are all plumbed identically. I just wonder if there is an off delay programmed on the solenoids within the programming that isn’t working on some units...I am at a loss. Anyone else experience this?
