JoelM
Custom User Title
Cold weather hit us hard last week and water wizard did it's job of blowing out all of the nozzles in the gantry but did not blow down the wheel brush hp lines. Both busted and had to be replaced. Should the water wizard blow these down as well or did JCC retrofit these brushes without regard to freeze blowdown?
If it was overlooked at the factory, can it be programmed to blowout when it does its freeze blowdown?
Also, does anyone have any suggestions to protect hoses from wall to gantry? Heat trace? etc?
Thanks in advance.
Joel
Thanks in advance.
Joel
