toddmullens
I wonder if the Boom Height Setpoint percentages were ever changed or needed to be changed when they designed the new boom count setup which decreased the total number of counts from top to bottom? The manual says they are factory set and not adjustable but I swear I changed them on a mchine once while i was messing around. I changed them back, but I cant remember how i was able to make them change. The tilt location value never made sense to me on that menu. I am willing to bet the setpoints percentages are wrong with the reduced number of counts using the count wheel retrofit on the boom.We checked and changed the recipes, but nothing made any difference. One machine has only two profile eyes the other has four they all work with no codes. The one machine has eyes with no wire connections in the cables. This only happens with certain cars. The first time I noticed it was on my wife's park avenue. The biggest inconvenience is when looking in the alarms next section for codes sometimes you have to sort through a lot of "while profiling the car front or rear eyes saw an obstruction" code. I installed the conversion kit on the machine with four profile eyes first and noticed the issue. We tried to figure out why but with no luck. A couple years later I installed the kit on the other machine and then the problem showed up on it. I have tried different spacing on the prox sensors also with no change
