I have a mark VII Aquajet and have some small streams of water dripping out when it is drying. a couple of customers have informed me just as a heads up. So I was curious if there was a check valve for this somewhere that I can change or if there is something i can do to fix it. Thanks
Depending on where it's coming from you might just be able to hook up an air blow down. Simply plumb an air line into the line, with an appropriate check valve, and have a timer controlled by the dryer function.
