Water Based Hydraulic Fluid
sparkey
Is anyone using the water based hydraulic fluid? What are your likes and dislikes with it? I am a little hesitant with putting water into a hydraulic system. If anyone is using it how long have you used it? Any hydraulic failures using it? Did you drain you system before completely before swithing to it?
pcb
Leprechaun Car Wash
Dublin, Ga
I have the same questions about this as you do. I would like to swap over, but I was unsure if it was something that needed to be used from the start. It seems like it would be hard to get the system cleaned out for the swap.
pitzerwm
Tri-Cities, WA
Sparkey, check out the threads in search, or at the bottom of the pages, you will find that this has been discussed before.
Washmee
Fullservice Tunnel
Canton, Ohio
I've been using it for over 15 years in my tunnel with no problems.
