Washworld razor soap in the spot free tank
SanDiegoSS
Anyone had this issue? I noticed bubble coming out of the top of the spot free water tank. peeking inside I see a thin stream of pink presoak coming up through the outlet pipe at the bottom. I am guessing a broken valve further up the system but was wondering if anyone else has had this problem a knows a fix?
bobcat9095
Check your check valve on your red presoak along with your danfoss and injector. Also your check valve above the manifold above your pump station. It's weird that it's getting into your tank.
SanDiegoSS
yep fixed it this morning replaced danfoss valve and we are working great, thanks for the help!
