Ryko uses one made by Breco Flex. If you have a section of belt you maybe able to have a local belt/ bearing shop order one with the correct pitch and teeth number. Kleenrite sells many automatic parts now also.
What’s your question, exactly? Do you not know how to thread it into the rollers? You can use the opposite side for reference.
Don’t know how to loosen/tighten the tensioners?
Need to know how much deflection is acceptable?
Do you have the Manual? I’m on site doing a repair on a 10 year old Razor3. I can check the manual and might be able to post screenshots when I’m done here. Shouldn’t be more than 30 minutes
Thanks I located it in my manual as well I got to looking close at it while I'm doing belts I'm going to do all the belts and all the rollers and all the idler rollers. I think I remember one of the technicians telling me when you replace the belts park the Carriage in the middle of the Bay.
