Uncle Sam
We are finding out that the older Vend-Master models were using different size wall openings than what is used with the newer ones. We designed Junior using the wall opening size that is listed on their brochure information. Our Junior vendor uses the same size wall opening as the newer Vend-Master; 32" W X 35" H. There may be some block cutting to do if you have an older vendor.
Uncle Sam
Uncle Sam
