I'm running out of room in my equipment room and wanted to add an IBA. Does anyone use or know where I could get a wall mounted storage tank for my RO and RO reject?
Thanks,
Kirb
I've done this for several of my customers. What I did was construct a support for however many gallons I wanted to store. Used horizontal tanks and have done 1,000 gallons so far. Each building is somewhat different. In one case I put the tanks up in the crawlspace and right above a block structural wall, even saving the cost of a support. In most cases the cost of support was always under 1,000. Please understand that to do this comfortably you need to understand load tables for structural beams. It's not rocket science, but just requires a good math background. I'll see if I can find some pictures to post.post some pictures.
I had a guy come in and build me a support rack. Its a 6" diameter steel pipe mounted horizontally between the walls, held up by two 3" diameter legs welded on. Now double it so there are 2 of them... then set the tanks on top of this frame. Very simple, very inexpensive.
I agree with mac, make sure whatever you do is rated to hold the weight.
