Hey Guys....any ideas?
I keep blowing the GFIC. At the start it would blow it at the beginning of the wax cycle, but now it is also doing it on presoaks also, I can’t get it to blow on any high pressure passes though. When I take all the leads off of the ASCO’s and ran the presoak the problem stopped, and as soon as I hook any one of them back up it immediately blows the GFIC. The wires inside the ASCO’s showed signs of corrosion so I replaced all the terminals for ASCO’s (brown, blue, black)….but it keeps blowing. Also many of the brown, black, and blue wires look black when I strip them, I believe the corrosion has been drawn up into the wires.
Does it sound like the wiring harness should be replaced?
Note: I also replace the GFIC breaker, and the orange terminal that the yellow wires connect to looks fine.
Note: All of these things mentioned above are in the bay, it was a retrofit, so there is always moisture around.
Thanks for any help
Thanks for any help
