Keep brushes on hand ,you should be able to replace quicker than pulling the motor, If the motors are not burnt up. I will let wiki explain the rest of your question
http://en.wikipedia.org/wiki/Brush_(electric)
I change the brushes and change out the filter bags, we have an extra set in our vac’s every September. When the bearing go bad we toss the motor. Sometimes you can replace the brushes in a motor that the brushes have completely worn down, it all depends if there has been any damage to the Armature. I have also found that the replacement brushes don’t last as long as the ones that came with the motor when it was new.
What bags are you using and where are you getting them? Thanks.No, you don't just replace the bags every year, you can remove them and wash them. I use a bag that's probably a different material than you have. It doesn't trap the dirt, so I don't have to change bags unless someone vacuums enough water to get them wet.
KTM300 said:What bags are you using and where are you getting them? Thanks.
I wonder if that has something to do with following the instructions for properly seating the brusshes at one half the voltage?
Thanks. Good to know.
As far as I know, only the Ametek motor brushes recommend this wear-in procedure. To get half-voltage, you wire the motors in series. Instead of one lead from each motor connecting to hot and one from each connected to common, two of the motor leads are connected together and the remaining two leads are hooked up as one motor, then the motors are run for 30 minutes with no load.bigleo48 said:Half The Voltage?
I'm not certain they'll fit in the Coleman vacs - instead of pulling up from the bottom and needing to be pulled tight to seal, these have a spring steel ring that you flex to snap into the opening, so that circular opening needs to be the same size as an Adams or Industrial vac to make a seal.KTM300 said:The ones you linked to are better bags and fit the same?
MEP001 said:In most cases, by the time the brush has worn down to the point of failure, the commutator becomes burned due to the arcing and replacement brushes will only last a fraction of the time they normally would. If you replace the brushes on a routine basis they never wear down enough to cause damage from failure.
