Vac it Up motors
What's the part # for the motor? This motor that died had a new set set of brushes on it.
i bought the domel repalcement from windtrax, but it did not work on my vac it up system. The bottom of the domel motor is not completely flat, so it did not seat up tight to the bottom of my quarter box.
It should be - it might have been damaged in shipping. UPS is so rough with packages that when I order Domel motors I have to tell them to ship them on their sides, otherwise the bottoms are damaged when I get them.
mep, these are the tangential bypass motors and I think they are built with slightly coned bottom. They work fine if you would put them on a vac with the normal hole in it. However on my vac it up system , they just drilled little 3/8 inch holes into a flat piece of steel, and the vac motor pushes up against the flat steel.
