Unique vaccuam issue
Cool Wash
Hope someone has a solution to this issue. I have ColemanHana vaccuam. When I was pulling out coin this morning, one of the vaccuams front cover plate would not open. I can hear key unlocked it and I can wiggle it but when I tried to pull out the cover plate, it seems stuck. Any idea?
Thank you in advance!
Rfreeman
Ft. Worth
Cover you mean vault cover?
If so you have a qtr stuck in there.
Cool Wash
Yes, it is the vault cover. I am going check it for the quarter. Thank you!
Rfreeman
Ft. Worth
Okay more than likely it's qtr. I've had it happen to me before when I forget to empty my vaults.
I usually take a hammer and tap on the front of the face of the vault cover while trying to remove the cover....eventually it comes loose.
Other than torching the cover for a qtr I don't know how else to get it loose.
Good luck
Another option I'v ued is open the covr to the upper compartment remove coin Funnel to allow better access to slot and use a combination wrench thru slot to push from behind on vault cover. Tap with hammer if needed.
Cool Wash
Thank you again Earl and Rfreeman. Your suggestions worked. I was able to open It. Appreciate your help !!!
