DbltheBbls
Here's the problem, my undercarriage spray turns on as soon as the the customer's transaction is confirmed while they are still at the paystation.
this only seems to happen in the morning within a 1 hour period, usually when the sun is in a certain position where it's lined right up with the sensor, aimed right at it. Could the sensor pointing right at the sun cause it to turn the undercarriage spray on? I can move the sensor back away from the opening a foot or so that the sensor would be in the shade if I need to. Again, and this is important, it work perfectly 23 hours a day, only during that 1 hour period do we have problems....when the sensor is pointing right at the sun. Anyway, if thats is the problem, this brings up 2 more questions, how fine of a beam is it? I have to line the path of the beams on each sensor so the beams are pointing at each other right? How do you do that? How presice does it have to be? I've also got a baluster (iron pipe sunk into the ground filled with concrete) about 6 inches from the wall that the beam from the sensor would have to go between, so how much does the beam flare? Would the beam hit the baluster if it was a foot back and had to go between the baluster and the wall, or is it more like a laser?
If it has nothing to do with the sun, how about a drop of water on the sensor? Would that cause this, or will this not cause a break in the beam?
Sorry for the long post....
