Two Enhanced Hamilton Goldlines
Status
Not open for further replies.
Roz
Goldlines were originally installed in 2005. None of the components are original. All have been replaced with new versions that have updated hardware, firmware and software.
New door installed within that last two years so we could upgrade to the larger display.
We changed Hamilton XE bill accepter to a Mars MEI and changed the bill holder to the expanded 1000 bill holder.
Added a Barcode Scanner
Changed coin hopper to dollar coin wheel and the coin accepted to a dollar coin only. There are two coin mechs in both units however we stopped accepting coins about two years ago as some bright customers would try to use a foreign coin which would get stuck and generate an error code. The code would shut down the Paystation until the coin was removed and the unit rebooted.
New controller with updated software.
Upgraded credit card readers to IDTech which accept swipe chip and tap.
Has voice option installed.
Has a keypad
Uses internet connection only. No dialup.
Has receipt printer
Has relatively new buttons
Has a custom skin for our wash but will swap out the original Hamilton skin prior to sale if desired.
Will be available in July when our new Commanders arrive. Will be professionally removed by our Hamilton rep/installer.
Units are identical except for rear on/off switch component as one has an electrical socket (not used).
Located in Berkeley Springs, WV.
Asking $10K each or both for $19K.
Status
