I'm taking delivery tomorrow of my new 60 gal Quincy 2stage air compressor. My old smaller compressor still works and I planned on using it as aspare. My new compressor has a max psi at 175 and I bout a regulator and filter to regulate psi. When adding my spare into the line, should it be T'ed in before or after regulator. I ask because I think it only has max psi around 125 or so. I planned on setting regulator around 100 or so, would that be alright, I currently don't run one with small compressor, I just didn't want 175 down the line.
A second question, I'm asuming the larger compressor should fill first and be used, preventing smaller one from running, but only if large goes out. How can this be fixed if this isn't the case.
Thanks in advance
Thanks in advance
