wcodyd
Hello,
I have a CAT 66DX 4,000 PSI 4GPM water pump. It is constantly releasing water on the relief valve, rather or not the trigger is depressed. Oddly, when I connect a pressure gauge to the high pressure side, the pressure will read 5,000 PSI.
Is this a problem with the unloaded or the valves? I’m trying to determine what I may need to replace.
Thank you!
Thank you!
