Troubleshooting Cat 66DX Water Pump
Hopefully this is a simple adjustment needed. Turn the black knob counterclockwise until the pressure gauge drops to the advertised output pressure on the unit. If it doesn't drop low enough you may have a bad regulator which needs to be replaced. Good luck!
